My nokia lumia 520 volume keys problem.
WPCentral Question
My volume key on the side of my noka lumia 520 will only turn down and the up button doesn't work so i can only have it on silent. Is there a way of adjusting the volume with out using the buttons on the side ? i.e manually like on the settings or something ? I would be very great full any advice on this.
Many thanks Craig form Maidstone.
If you have WP8.1 you can use the sliders when they display by pressing either of the volume buttons. If you don't have WP8.1 I'd recommend getting it. :)
yagoldt
