ahmadsamhann
- Sep 16, 2013
- 49
- 0
- 0
Really the battery changing must not be shown to NOKIA people. it will void the warranty.
By the way if u r using WiFi then make sure it runs under lockscreen
then set mail sync once a day or manually
keep brightness LOW [not automatic]
the Battery discharge is safe as you are using IE and Skype.. I too get 20 25% on heavy use. but it reduces after sometime.
by the way HOW you know BATTERY is FULL??
maybe screen brightness is set too high?
The battery is taking 1 hrs 20 minutes to get fully charged. Is it normal guyz? Someone mentioned that it takes around 2 hours ??
HI,
I am having a similar issue with my 920. This is the second I have gotten from AT&T because the first one was also having bad battery life. I feel this new one is worst than the first
I fully charged it last night at 1 am. Right now its 7:22 and I am at 28%. I have not been using the phone since its been over night
Looking at battery pro its discharge speed is at 9.23 percent/hour
Currently On: Wifi Locating, Cell antenna
Currently Off: Bluetooth
Running in background:
- Active Fitness
- Battery
- Battery (I have 2 different battery apps I have installed but only installed after I started seeing issues)
- Bing Weather
- HERE City Lens
- Linked In
- Yelp
- App Social (BLOCKED)
- HERE Drive + (BLOCKED)
Getting very frustrated with bad battery life
Why you put HERE CITY Lens?? I m thinking Location service is ON [settings -> locations]
switch to 2G only for a day use rest as you are currently using let us know if any improvement.
this is normal.. I meant 2hrs nearly from LOW [10%]
now the battery app could not be trusted. I wait for the second Notification from the app. in My experience the battery drains faster if I remove charger as soon as I stop with the notification.
I would like to add that TAP TO SHARE eats battery![]()
Thanks. So, according to GSM Arena, the battery lasts for only 3 hours 50 minutes, when it comes to browsing (they must be using WiFi). In my case, it lasts for around 3 hours 30 minutes. I'm over 3G. So is it normal ??
Thank you. How can i make sure that the battery is fully charged? What is 'second notification' and all ?? Plz explain, how can i know that the battery is fully charged ?? Thanks in advance.
Friends, how many hours out of it, am i supposed to get, if my sole purpose is browsing the web ?? GSM Arena mentioned that it will last for 3 hrs 50 minutes. What about your results?? Plz do post your results. It will be very helpful to me. Thanks.
