Speaker problem with Microsoft Lumia 640 lte, how can I fix it?
Speaker problem with microsoft lumia 640 lte
Is this fabric problem or not, that speaker is not working, then you press the cover near speaker and it works, and sometimes again doesn't work? Give the phone to service or no? Anybody else with similar problem? Thanks.
Re: Speaker problem with microsoft lumia 640 lte
I would suggest that there is a problem with the connection to the system board. When you apply pressure, it creates sufficient connection to allow current to flow to the speaker.
Depending on how long you have owned it, although the 640 is a fairly recent device, if possible, I'd take it back to where it was bought. Different markets have different warranty terms, but that would be my first step. In the UK we have pretty good rules in this instance. I would claim it's not fit for purpose. What good is a phone you can't hear ringing.
Warranty it! The phone is less than a year released so it should still be in warranty unless there is evidence of water or drop damage.
longinotti101
