System Tiles with custom folders (now with Lock phone tile!!!)
Re: System Tiles with custom folders!
Wow...genuinely very useful app. Thank you. Look forward to updates.
Nice got it...
A question why has no developer created a shortcut to battery saver ?
I want to be able to turn off or on or configure it easily How hard could it be to create
a shortcut, or is there an agreement by developers to never create one, (battery meter app installations would decline)
I know many wouldn't get a battery meter ( they drain the battery while telling you the %) if there was a shortcut.
Why no battery saver shortcut ? it has to be a conspiracy :wink:
Nice got it...
It is a new shortcut, introduced with GDR3. Wait a litlle and there are will be tons of apps with this tile :)
WOW you did !!! BTW what does "sim apps" do? I have Amber/GDR2
Few questions:
1) is like App Folder by Samsung?
2) it's possible to have notifications from apps inside folder if i put it (folder, not app) in start menu?
TIA
A suggestion add "saver" to battery, many battery meter's tile icon look very close to yours
and it doesn't stand out from the crowd -besides this is the only battery saver shortcut
to date -you should celebrate it with choice of colors so it stands out or if it could have a battery icon
in a circle like ∅ over it or over a B would be cool. Anyway thanks I've wanted this shortcut forever !
Does anyone know a app for a wifi live tille and toggle it on/off by tapping without going into settings.
It is impossible to implement. Third party apps have no access to system settings.
Hi there, Can I request for adding 'Brightness' tile in your app? It's the only tile I felt like "Missing". BTW Thanks for such a great app. :)
Thanks.
A shortcut to audio !!!
I hate that I have to open settings/system and scroll all the way down to find audio and
then open it to adjust when I'm listening with head phones or connected to aux in my car.
Great app and battery saver is easy to pick out even in a small tile !
Guyz, all available at this moment settings shortcut are implemented.
If something new suddenly appears , I will add it.
What do you mean "all available" all that can be a shortcut or ? appears where ?
Nice app BTW
All available shortcuts in SDK. I think in GDR3 we have a little more than MS gave us, but we need to wait till MS give us emulator images with this version of WP.
Hello, very nice app. Would it be possible however to add other tiles in a folder? I'm thinking for instance of Nokia maps and drive (create a GPS folder)? Also a link to Settings would be great. Thanks for your work.
Found a glitch with all your pinned tiles, when you hit the back button it just comes back to that system (ie Bluetooth, battery saver et al )
unlike other 3rd party shortcuts which go to the start screen, I thought it might be a bug on my phone but I tried every 3rd party shortcut
I have and hitting the back button takes you to the start screen, it's not the end of the world but I thought you should know that if you already don't.
Oh! That is a bug. I did some changes in the app, but seems broke this part of it.
will fix it right now
lerato Mokoena
