Verizon 928 and Mobile Hotspot does not work on 10536
upsidedown
114
Can anyone confirm if it is working with the 928? I have not gotten MHS to work on 10166, and of course MS confirmed it would not work on 10512. When I go into the All Settings -> Network and Wireless -> Mobile Hotspot and try to turn it on their I get the message:
Connection not shared​
Mobile hotspot isn't currently available​
Can someone else confirm whether they can get it to work on a VZW 928?
Thanks
We'll trade info, you tell me how to get LTE and data to activate and I'll work on getting the hot spot going.
My lte worked as expected before and after upgrade. i have an old unlimited data plan and pay the extra 30 for hotspot. It works on 8.1 but not on 10.
I'm running unlimited as well, rolling back to 8.1 currently as I use that as my primary internet connection when home. I do like what I saw though, once it is RTM it should be good to go.
I have The same issue with Lumia 822 i dont get host spot i have 20 gigabyte for My phone ande i like share with My tablet but after upgrade to 10536 i lost this functionality. Please help
ok look how i get fix is easy, just go back to 8,1, install a app called access point you will finder with another app callerd sysapp pusher, after thats just install w10 again but try to install the more fresh posible no install all you app until you get 10
longinotti101
