Why is Edge using so much battery?
BGrewer
276
I've noticed recently that my battery life has been dramatically reduced, and I think it could be due to Edge, does anyone if there's a way to reduce the amount of battery life eaten up be Edge
Thanks in advance!
HyperKid
298
Thanks in advance!
Close the background process, make sure that you don't leave any page opened while SUSPENDING the app & finally close it from the multitasking menu. I can guarantee you that performing these mentioned actions does INCREASE battery life.
Steve Adams
Banned
Nov 29, 2013
1,296
It's not when its closed, When I use edge, the battery drains very fast. I use IE11 and its fine. I just don't use EDGE unless I have to.
jruasap
