I been having issues with my Surface 3 battery draining rapidly. I am currently using Windows 10 and I had no issues with Windows 8.1. I put it to sleep it wakes back up, or If I Shut it down it turns back on and just continues to drain the battery. I was at 100% off the charger. I went to use it after 7 or so hours off the charger and it is at 10%. Any help would be appreciated.
