I have been using Samsung Omnia W for last one and half year. Recently I changed battery after 7.8 update since then it is madness. few things unusual-
1. Battery does not seem to be charging fully as after an hour or so though it shows charging but phone is cold and % increase is very slow. after 2-3 hours also it reaches only 90% and simply refuses to move. Trying to reach 100% damaged one battery and now replaced with another one. It only reaches 60% or so after 2 hours
2. Once charger is removed and phone used for few minutes, battery remaining jumps by some odd amount like from 60% to 82 or 91%
3. Phone discharges very slowly- even after a day's use it is still 40-50%
4. problem starts now from 40-50% to Switch off, it sometimes just takes one short call. even with no use it sometimes takes 5-10mintues from that level to switch off
5.Battery is completely discharged and it takes 10minutes of recharge to turn it back
6. Even if I charge it to 8-10%, after little use it shows 30-40% and then will switch off as above
Done soft and hard reset, nothing works. I am thinking of just throwing it away
HELP PLS...
HELP PLS...
