10572 Wireless charging: device does not detect when removed from dock
schtompi
Hi Folks,
I have a 830 (RM-984) and DT-910 charging station. I did not run any W10 previews earlier due to stability/performance issues, but installed 10572 last weekend. It took several tries and factory resets but the device runs pretty good right now (besides a sub-par Groove app;)).
However, I have an issue with QI charging:
If I remove the 830 from the docking station without waking it up beforehand (pressing the power button), the device still thinks it is connected to a charger. It displays the charging symbol next to the battery icon, the battery level stays at 100% even after several hours and I sometime get the notification that my device charges slowly :) A simple reboot does not solve this. Instead, even during reboot the device thinks it is connected to a charger and therefore directly reboots after shutting down (which normally only happens if the device is connected to a charger).
I have to remove the battery to fix this.
Anyone else having this issue with wireless charging?
Best regards,
Schtompi
