70 Battery Use by Messaging+Skype?
Mesbah
396
70% Battery Use by Messaging+Skype
It's couple of days I noticed battery is drained during night when 950XL is in Quiet Hours mode and culprit is MESSAGING+SKYPE using more than 70% battery for no reason as nothing is used at night except these dumb apps in background. Any solution is found for this?:grincry:
Re: 70% Battery Use by Messaging+Skype
Hi there,
Well I see that you have stated your own problem's solution.
Close them in the background and then try to see what happens.
If then is the same situation,feel free to reply back. :D
Problem is that since I purchased 950XL those apps were in that same condition in background at nights but not using greatest battery level.
So you're telling me that they are reacting now not before?
Disabling Messaging+Skype in background what happens to incoming Messages?
Or you can do like this, try to disable Skype from your messaging app by logging out.
As mentioned by another fellow here, there is a chance you won't receive live tile updates if you close the background agent. So try the first option.
OK folks, glad to report that killing ******* Skype dropped battery usage substantially. What a useless app is Skype each time I try to send a simple sms it demand FUNDS as though I am ordering a cargo ship of merchandise from China:sweaty:
Haha I knew it from before.
Skype is A HUGE RESOURCE HOG.
Anyways, congrats bro :D
BAD NEWS:
Stupid SKYPE although signed out keeps signed in automatically then draining my battery. I am very disappointed by inability to totally removing useless SKYPE or curbing its unauthorized signing in.:crying:
how come I hear so much about the messaging app skype problem but I never see it in my battery usage as high. It's always Edge for me the tops, or nextgen news reader, or mytuner radio pro, or pocket tanks :)
Fortunately I succeeded to remove SKYPE from 950XL and I am waiting to see if MESSAGING+SKYPE will still drain battery. I need help to also remove stupid SKYPE FOR VIDEO :crying:
Nope. You can't remove video unfortunately but glad you solved your issue
Well for me edge is top as well but maybe we don't use messaging and Skype as much as they do..
950XL BATTERIES:
...and more miserable thing is that I cannot find a single 950XL battery on sale anywhere even MS Store. Cannot believe MS Store sells 950XL but not a single battery found throughout MS Stores.:confused:
950XL BATTERIES:
Oh I see.
Why don't you try another store or online?
But I thought the issue for messaging and skype was background use.. I do open it daily... though I don't really do a lot of messages on it... it's mostly IM+ and whatsapp for my messaging.
YeOldRam
