Battery Saver not able to use via Settings
stevieby
Has anyone else had the issue where going to Battery Saver in Settings just does not do anything?
On a Nokia 920 UK and yes I can see Battery Saver working but I want to turn it off sometimes. I realise it's beta software but was wondering if someone has found a workaround.
Any ideas? Store apps are updated as far as i can tell.
So you navigate to battery saver in settings and nothing at all happens? For me I'm taken to the battery usage screen. You should see a Battery Saver app in your app list - try opening that, do you have the same results?
longinotti101
