For my job, I need to be able to prove my location using my phone.
yeto
155
For my job, I need to be able to prove my location. My company will allow me to do this using my phone if I can come up with a way. Is there an app available that will show my gps location and then maybe I can take a picture of the screen using the front facing camera and a mirror? Would this even work? Could anyone offer some ideas or suggestions that might be easier/better?
Thanks in advance for any help,
yeto
you could use any map app to find your location then take a screen shot and send it via email
You can send your location in a text message. When writing a message just tap attach and my location.
None at all. On most Windows phones, just press the power button at the same time as the Windows key/icon.
Badranath17 has it right though; it's much easier to just click "add location" (unless you're hoping to build a catalogue of mock locations to send in to work).
Just hold the sleep/wake button and the windows button at the same time. Then the screen shot will be saves to your albums under screen shot
Gmaps pro has latitude but GPS Calculator lets you do raw GPS calculations as well. With GPS calc you can get the raw lat and long and take a screenshot.
1337GameDev
