Internal space problem & Photo sync problem
AmGaD-SaLaH
350
Hello brothers , Hope everything is fine for all you :D
I own Lumia 1320 internal storage about 8gb .
First problem :
My internal space is getting smaller Sometimes
Images
As you can see i've 195MB of "Documents" . The funny thing there's no Document file on my phone even my SD card :(
Also the "System" space is getting bigger :(
This is the first problem !!
Second problem :
In the Images Hub .. IF I open the "Album" section , I see Online at the bottom of the Hub , Including Facebook Images + One Drive Images :( !!
How can i remove them from the Images Hub ?! :(
Thanks in advance
For the second problem i don't think it can be removed as microsoft windows phone has the two albums inbuilt in the album section. It wont cause much of a problem. Just don't sync photos in one drive if you don't want anything to show up in your one drive album.
Sent from my RM-941_im_india_204 using Tapatalk
For the first problem, I think you should go for a hard reset. This would fix almost many of the issue you are going to face while using 8.1 also format your SD card and backup your data from settings backup option.
