Is there any way around webcam problem in some flash applications?
bangoban
11
I would really like to use my S2 with tinychat. All the requirements are there however some weird thing happens specifically with tinychat. When it comes to selecting what cam to se there are the two options, rear and front. However only the rear cam is selectable and it says the front cam is in use by another application and im assuming this is because they use the same driver and for whatever reason tinychat defaults to the rear. However on other websites ive tried like chatroullette I am able to select both cams fine so its not like its out of the realms of possibility.
Your report indicates, that there is rather a problem with the tynichat web app instead of anything you could fix on the Surface.
clout
