Same, both on 5% to keep it stable for the test :)
Thanks, Geo. Very interesting.
I would also be interested in seeing the same graphic of your i5/8/256 with the factory default settings. (I'm assuming that the only setting you modified is the max CPU). I would find that graphic much more valuable to compare your underclocked i5 with than your Atom.
This is on balance default as Microsoft set it So same difference started up video, turbo kick in and heat went up, fans came on doing the same job. a lot of waste power and energy, typing this is cooled down again but as soon as I go on the video it will turbo again and fans will kick in and it will get hot. it had to drop to 0.9ghz to cool it down lol see very unstable,
Excellent! Thanks again, Geo.
Is there any downside to underclocking? This looks too much like a free lunch. :cool: I'm guessing it would slow down some programs, no?
Maybe, maybe not can't really say :) I mean in theory yes.. in practise hmm its hard to say more TESTS ARE NEEEDED!
Interesting. It took about 5 minutes to render the image to 20% (from about 3:40 to about 8:35) with underclocking and about 2 minutes 13 seconds without underclocking (from about 12:29 to about 14:42). In other words, it took more than twice as long while underclocking. That's pretty much what I'd expect.
Geo, how would you describe your conclusions from this test?
If you like to keep you device cool, healthy and safe but don't mind waiting underclock it, if your going to upgrade In a year then that does not matter, but really best thing to do is when you need the power switch it from powersaving to balance when you don't powersaving, once you finished what you been doing in balance switch to powersaving to cool it down faster, I run it in power saving mode all the time and it works for me. when I render its not when recording so its much faster so its not a problem, gaming can benefit from lower ghz as well find 2.0ghz is best, I think 2.5ghz is to much for this little machine
I can test skyrim on 2.0ghz vs 2.5ghz
I agree. Also, most of what we do (email, websurfing, MS Office, etc.) is much less CPU intensive than what you did in your test. With our typical usage, we probably wouldn't see much performance difference from underclocking. This question is how much additional battery life would we get by underclocking and that depends on our usage, which is much more difficult to benchmark.
One of these days, I'm going to create my own power saving plan(s) and see what happens. Thanks again for all your good work on this.
Well I could try to do a battery test but I will need a weekend to do and I am sending my surface of for repair this week, so give me two weeks at most to do the test.
But I don't think it will help to much
So if I want the best performance for gaming on a game like Dota 2, what do I want to set my min/max to?
Also, is there a way to do this and get sleep back? If I re-enable connected standbye will that undue my CPU % changes?
Of course, in fact that would give you best results as you could clock it a little bit higher
Anway, the values on your screenshot are your recommended values to save battery without sacrificing performance?
I am new to underclocking and undervolting on PC, though I do this on my phone so I am not exactly n00b on the topic but the way I see it, underclocking in theory is limiting performance, though when the computer gets heated, that will also limit the performance and here underclocking has its advantages. I don't want my device to limit its performace, I want to be able to run Photoshop on my SP4 i7 smoothly at demand, but I want to conserve battery as well, so I am torn here.
I know this is not the thread for undervolting but I have a question. I have a value that I set with intel XTU and my device is pretty much stable with it. After reboot, the values that I set on intel XTU will automatically reapply without running the app or we need to run the app at boot and activate the profile again to set the values?
Not recommended values, still testing, they where just the ones I had back then but I am playing round to see what works best, found something cool out, I set high performance on and set min to 5% and max to 74% and the fan is not coming on at normal use, going to try skyrim in a bit and see what happens but I think this might be better. going to do a battery test some weeks from now
Right so undervolting which I tend to not do as I don't like changing core setting, I don't class power options as core setting as you use windows it self to change it not an another program but lets say I did, I found that undervolting seems to need the program running to work but that may not be the case, I used to use intel XTU but now I use throttlestop as its a much better program for such things, also you can turn off turbo boost on throttlestop, so you could give that a try, I am not the best person to talk to when it comes to undervolting
Once you changed it, you can re-enable connected standbye and your poweroption will stay the same but if your switch it will disappeared I think.. might not but pretty sure it does, well try something like this %5-74% 10%-74% 5%-65% 10%-65% or even 35%-74%, more tests are needed
KyrrcKentucky
