Replacement for battery cover?
blckDTshadow
27
Hey,
The back of my Ativ S just splintered. Not too bad, but I would like to replace it. On Amazon here in Germany it's 13? though. Has anyone a hint, where I might be able to get a cheaper one?
Thanks ahead.
PS: On a side note my phone is getting slow. Is it worth to reflash?
Hey,
13€ is ok from my point of view.
I replaced the full rear-housing of my Ativ S and the lowest price i found for the back cover was 10€ (add 5€ for the shipping fees).
Note that the back cover available for 4-5€ on alibaba are fake ones.
No need to reflash. A reboot is a good start. If it's still slow, try a hard reset.
For the battery cover, I don't think this will be a problem (just check the clips position).
For the rear housing, it is usually one because the rear housing of your phone is its antenna. And the first one i ordered was missing connectors.
Then I ordered an official one. ^^
BJB
