Surface Pro 3 External Monitor not connecting
opsservices
I have a Surface Pro 3, a Dell ST2420L monitor, a docking station, a HDMI cable and a Microsoft SP3 mini display port to HDMI adapter. There is no way I can get the monitor to work on the Surface or the docking station even after 2 hours with Surface support.
Solved
So your have the adapter into the Dock, then the HDMI cable into the adapter?
How do you have the two monitors hooked up? Good to know the active adapters are necessarily needed.
Posted via Windows Phone Central App
tahirmehmoodkhokhar
