While using pen + modifier keys small window won't go away
Isaac Gray
Hello, so I'm using the surface book with performance base. When I'm using the stylus and holding down any of the modifier keys a small window will pop up showing which key I'm holding down. This is only when I'm using the stylus. It's very inhibiting to my workflow and I can't figure out how to disable this feature. I've turned off sticky keys, so that's not it. Does anyone have any ideas? Thank you!
rajdipprimeview
