L925 Running Here Maps & Battery will not Charge
Skaterbuoy
3
Hi, Some advice from other road users please?
I have Lumia 925 and use the Nokia Here Drive app. Whilst out yesterday I noticed that the phone is not able to run the Dive app and charge the phone sufficiently at the same time.
Although the phone said it was charging via a 2.1amp adapter and cable, it just ran out of change and powered off.
After the phone re-set and as it was still connected to the power source, did after few minutes powered back on and seemingly continued to charge.
I have had problems charging previously, but I thought getting a 2.1 amp adapter would have solved my problem
My question, is there an issue with my phone or adapter, as to why it can't run the app and charge sufficiently at the same time?
I have the latest Black update and associated firmware o/s updates. Any comments would be appreciated
Cheers
Paul
DBDev
2,380
Welcome to WPCentral!
It should charge, however I have seen other people with the same problem, so it might be that Here Drive is taking that much power...
ratsttam
351
Are you running with the your local map donwloaded, or are you pulling the map as you go? Running GPS and a stream of Data can be pretty rough on any device.
Where are you seeing that it's getting the full 2.1a charg, instead of the .5-1a normal charge?
KarateDad
82
It seems that running the GPS, the screen and data takes most of the power from an adapter. When I run Waze, my battery actually drops while plugged in!! I do get a slow charge on Here Drive, but I also went to a 2Amp car charger.
mcheiron
216
I have the same issue with my 920 and Here Drive. Even plugged in, standard charger, the charge is dripping and after 3-4 hours the phone is dead. Unplugged it takes 1 hour. The map is local.
DrPendragon
