Help with USB Data Transfer Speed with DJ Controller
Hi all,
I am using a Surface Pro 3 with a USB 3.0 Powered Hub and plugged into that is a Pioneer DDJ-SB, and a Wireless Keyboard & Mouse. When I go to use the DJ controller with Serato DJ it lags a ton. When I plug the DJ Controller directly into the Surface I am able to use it without issue, however, I'd like to be able to use my keyboard and mouse as it makes it a lot easier when mixing.
The DJ controller comes with a USB 2.0 cable (not sure what its called but you get the wire with most printers) and I'm wondering if I can get a similar wire that is USB 3.0 or if that would even work.
Can anyone help?
Hi all,
Can anyone help?
