Can I get some help with a few problems I am having after the Denim update?
csNC
Re: Problems after Denim update
I have a Lumia 822. Yesterday I updated to Denim. Now, I cannot access any of my photos, nor do an attachment in an email. Furthermore, under Settings, I cannot open the following systems:
notifications+actions
Wi-Fi
VPN
storage sense
project my screen
sync my settings
quiet hours
language
accessory apps
Under Applications in Settings, I cannot open:
photos+camera
I would recommend to others who have not yet updated to Denim NOT to do so until and unless the BUGS in Denim are resolved. I consider it a major problem not to be able to open Wi-Fi sense and other systems, or to be able to see my photos and make an attachment.
Mr Lebowski
1,076
How do I uninstall apps in settings?
You can't, you can update them however. Try using SysApps Pusher it has most all (extra+info but not motion data) of the settings apps and you can update them there if there are updates. That may fix some issue you're having but only install them if it says UPDATE.
KTurner65
23
Wi-Fi
VPN
storage sense
project my screen
sync my settings
quiet hours
language
accessory apps
photos+camera
I rolled back to Cyan, updated to Denim, then updated to DP, and this seems to have solved all issues bar mobile connectivity...
csNC
Pardon my ignorance, but can you provide a link which tells the steps on how to roll back? I am not really sure what version I was running prior to the update. I received the 822 new a year ago, and there was one prior update, if I recall correctly.
Rakesh Rocky2
355
If you need to uninstall then I guess you have to go through the process you outlined. My experience was that reinstalling the app, whithout previously uninstalling it, corrected whatever errors were causing the problem.
Yeah that's what.. If your apps are updated you cannot re install there would be no option to install... Just view button
KTurner65
23
Update: the mobile connectivity problem seems to be related to 4G. If I put the highest connection speed to 3G, then the connection issue disappears. Any suggestions?
Slovenix
878
Maybe because 4G signal is not covered well in all areas in your country. Same with me. It's nothing unusual. If you mean internet connectivity then I don't know, but I guess it's the same thing. :)
Timbre70
934
Having the same issue even on cyan. Reckon it's the weird way wp behaves. So, if 4G is not matured in your area, better set it to 3G. The system doesn't know how to downgrade when 4G is absent.
KTurner65
23
I noticed that cellular connectivity is dropped when the phone is connected or is attempting to connect to 4G, which, as you say, is not so good in my area. But I never had this problem with cyan, which makes me think it's a firmware problem.
Carnes
