10586 on L830 - cellphone overheating and battery drain
BadrcBR
I decided to test the preview for the first time on that build. So i went straight from 8.1 to 10586.
My 830 start show the battery drain (about 10% in 10 minutes of normal use -> using edge with wifi, brightness on medium, nothing updating ou downloading...). Before that my L830 got all day use (12 hours at minimum). I noticed the crescente overheating... i try hard reset and nothing... try the recovery to 8.1 and still the same problem...
Someone have the batteru problem with 10586? some ideas to fix that?
There's many topic about that, use search function.
During first hours / days after upgrade your phone is updating all core and addedd apps form store. It consumes a lot of battery and cpu %, causing overheating
you read what i said? doesn't have any app from the store or updates... they finished...
I just used the search and don't find the same problem... but if you can help with something more than just post SEARCH I appreciate it
I apologize :(
longinotti101
