Surface Pro on 18362.1 does not switch on after sleep
mr_poobah
8
Hi
Running 18362.1 on surface po and it seems to be a pain to switch it on after a sleep, find i have to repeatedly press the on/off button in 2 second burts just to get it to switch on
if you press the power switch once it shows the windows icon but then dissapears after a few seconds, repeatedly pressing the button in 2-3 second burts finally gets it started
whats happening?
There will be both hardware and software issue in your Surface Pro. Try to search out the nearest service center of your laptop or try to reset or reinstall your windows and if this doesn't help you then you will definitely have to go to the service center.
Michael Niehaus
