Problem in Lumia 925 : Wifi, Bluetooth, FM Radio, Internet Sharing, how can I fix these problems?
phone_newbie
I have many problem in Lumia 925 :
Wifi - when I try to switch on, it says "Can't do this right now". Because of this,
I can't update to Lumia Denim (still Lumia Cyan), change phone language, download offline maps, download large files
Bluetooth - can't switch on (stuck to off)
Internet sharing - it says don't have internet connection
FM radio - "loading..." appear and stuck like that for long time
I tried "reset your phone" from setting, hard reset, Windows Device Recovery Tool (firmware 3051.50009.1424.0001 and it says the latest update). Result : No change at all, still have the problem.
Anyone know how to fix that?
Re: Problem in Lumia 925 : Wifi, Bluetooth, FM Radio, Internet Sharing
Even though it said latest update, did you chose to reinstall?
You will need to sign up to the Windows Central forums, so that you can reply to this thread to get more help.
yes I reinstall using Windows Device Recovery Tool, but still have problem, no fix at all
The only other thing I can think of is for you to install the Insider app and chose the 'Production' ring.
Then check for updates.
Nated2
