WM10 release build (10584.218) issues and solutions
After the newest build of windows 10 to public was updated, the phone's (lumia 730) battery life has fallen substantially, the apps automatically exit and start screen appears all the time, the phone gets heated up at times also.
Yesterday, my phone's battery dropped below 20% and battery saver was activated automatically. As a result of this, the "Action Center" menu didn't appear anymore. As soon as I connected the phone by using a power adapter, the menu was immediately working again :-) Funny issue... Can someone confirm?
.218 after two days. I went to sleep yesterday and when i woke up today, the battery discharge rate was 0,3% per hour. This was so far the lowest result of all time to me...Lumia 950, cellular data off, wifi off and location off!
Whenever I update, I tend to forget how things used to be before.
But I think that when in landscape mode you had to swipe dow to get the Action Center and notifications. Am I wrong? Now when in landscape I have to swipe from the left side (top of the screen as if I was in portrait mode) and the action center and notification area behaves as if the phone was in portrait mode. Is that correct? My device is Lumia 535.
It's always been like that, that's assuming you use center only form time to time.
I think will be unusable in landscape mode
Anyone else experiencing terrible battery drain after this update?
Lumia 950XL
That's normal for first hours due to core apps updating and system caching and sync. Usually it takes a couple of days for full performances, check Ondrive settings and disable video upload, check background apps (they now are all allowed) and log out video skype
Can anyone suggest me how is the build (.218) working on 92x series?
Does it have the following bug:
1. Screen flickering issue while changing songs
2. Any Application crashes
3. Battery life & sms sync issue
Any other serious problem especially for L925 like glance screen not working, phone hanging during call??
Running a 1520 and I'm seeing Cortana issues. Random crashes, but the thing that is really angering me is taking a note to OneNote. Cortana says the note is stored, but it never shows in Onenote.
I'm getting insanely good battery life with this build.
Lumia 1520
Re: Latest Build .218
Just wanting to know if anybody (especially 830 owners) is experiencing a hitch in the audio for SMS notifications when paired over Bluetooth? It's as if the phone lags out for a few seconds. Other notifications seem fine, just SMS since it's what I get most often.
Today the camera in my Lumia 535 froze with a green rectangle occupying all the screen and hiding even the nav bar and action center. I had to restart the phone.
I hope this is just an isolated case and not a serious bug.
Biggest pain is that on my Lumia 640 almost every time I try to "Share" a photo, tweet, or web item via Messaging it takes two attempts. The first attempt will attach the photo fine, then I add the recipients, then when I am typing the message it crashes, sending me back to the photo or article. If I repeat the process it works! I have found that if I skip typing a message it almost always goes if I act quickly after selecting the recipients, but if I wait too long it crashes.
some applications grey out and I cant uninstall and when I reinstall it shown 2 times. Grayed out and Solid, also many applications like facebook messenger are not working.
Tile picture changes to Full screen picture whenever I change the background using Photos app. That's the only bug I encountered. Though I'm not sure whether the bug existed in the previous build because I just found out.
For my 640xl this is definitely downgrade from 8.1 Yes,it looks nice,there are more features but what's the point if with all the good stuff comes all that bad stuff and good one doesn't really matters anymore. I don't know where do i star? I've sent so many feedbacks about bugs and lags that i even don't remember all of them. I'll just point out some major issues. Phone is sgnificantly slower now,some of the apps might even take 10 secs to open. If previously i charged my phone basically once in two days,now i usually do it twice a day. Rich capture is such a mess. First of all,even my old LG L9 is capable of taking better quality pictures. Second thing,camera app often crashes,somitimes it takes forever to save a picture,even if i exit the app and go back it still shows that it's being saved.for some of the pictures you can't adjust lighting,it gives you some kind of error. My phone even decided to restart few times and after that i wasn't able to open notification and action center. All these problems usually happens when i try to use rich capture. There are problems with many apps. Fitbit,for example,can't be used at all. Let's say you're tracking your excersise. You lock the phone,unlock and when you try to use app it crashes,no matter what you do. Even if you restart your phone and you want to start all over again you won't be able because it will say that you already are tracking your excersise. And there is more than that,these are just few thing. From loving my 640xl,i soon might start to hate it,seriously...
zlay12808
