WM10 release build (10584.218) issues and solutions
How is this build does in lumia 735? The last redstone build is crap and I want to roll back
My battery is totally f'ed since this update.
Posted from my 950xl.........while on the can
1 - disable Onedrive video ulploads
2 - disable Photo "Show Onedrive pics"
3 - complete procedure for logging out Skype Video
4 - check your background apps: now are all ON by default. Disable the ones you don't use, first Skype and Edge
5 - wait a couple of days till phone stop sync and caching
I've seen that the action center doesn't work anymore when the battery of my Lumia has fallen below 20%. As soon as you plug it in, the action center is working again. Could re-produce this behavior just once.
I'm I the only person have an amazing experience with this build on a Lumia 1520? I didn't even hard reset and things are smooth with insane amount battery? Maybe this build was for us older phablet fans.
My 640: SMS messages received before update to .218 got doubled, tripled or quadrupled and one message after update (already read) pops up in notifications every day... Update from 8.1 didn't do things like that.
This update killed my 1020 and I had to use the recovery tool.
I have since got my 1020 back up to .218 and it is running smoothly now.
Same here with my 925, first time I could recommend it for daily use. And a friend of mine says the same about his 920.
Mine did that to and I turned off synced message settings and since then it stopped,but before that I would sometimes get messages from months back
On Lumia 640 LTE Single SIM I got the following issues:
  • most of the apps are doubled (one installed, second one pending)
  • I can't change the device name
  • all messages are gone
I've done the hard reset twice and there's no change. I've even tried to uninstall the app and then reinstall it but after a while the pending one shows again.
Any help?
Any help?
Someone correct me if I'm wrong but some have found a solution to be going to the store, pausing all updates then resuming then cancelling each update that rocks up with an error. That's for the double app bug.
I'm also experiencing a massive battery train on the latest stable update with lumia 435,and using battery manager I found the culprit,Microsoft Edge,however,when i click on it I cannot set it to not be used in the background.Can you fellas stop it?
Any help?
Cancel the pending apps form store list, that happens when you don't tap yes when phone ask you to delete previous installation apps in sd card.
You always tap yes, so phone can download and install them again cleanly. If you tap no, phone is obliged to instal again in phone memory, so they doubled
Sdiolutola
